QUOTE(cary_todd @ May 14 2010, 05:09 AM)
Price shipped to 72903 please.
Problem is, I have power to mine, bulbs are good but apparently sockets are shot. Is there a way to tear into this thing? ....anyway, as the title says. I actually have a friend who wants to ship me one but he is on vacation and would be two weeks before I can get it.
After 3 years I am just about to give my project a first drive. ...need that tail light working.
shoot me an email.
ct
What makes you think that the sockets are shot? More likely it's a corroded (white stuff usually), loose, or broken connection somewhere.
They're pretty straight forward electrical set-ups, try these first:
1. Clean all corrosion in the sockets & where the harness plugs in, etc. with Wurth Electrical Connections cleaner & those fine electrical wire brushes sold at Home Depot/etc. & FLAPS, steel wool on a toothpick or Q-tip works in tight places too.
2. Check all wiring connections inside & re-solder if needed (inner housing is riveted to the outer housing IIRC, so try not to remove it if possible).
3. Check the end of the wiring harness itself for breaks & loose connections.
BTW - A good way to eliminate the internal wiring problems in #1 above is to hook it up to the working driver side & see if it works there, but still a good idea to clean the connections & sockets on both sides anyway after all these years.
4. And of course, check the fuses & bulbs that they're all good.
5. If still "No Joy" - then look for another housing to test in the right side to make sure it's not in the harness as well.
