QUOTE(schuh1129 @ May 15 2010, 11:12 PM)
I'm in need of the hard brake line that runs from the soft brake line off the caliper to the center of the my 72. I also need the hell hole area sheet metal and the mirror image on the drivers side. I also need a CV joint bolt, I have one that is stripped out.
Brake hard lines are available at the FLAPS. 10mm x 1,0mm European bubble flare. You didn't say right or left or front or back- measure - they're all different...
Restoration Designs for the sheet metal.
CV joint bolts should probably be considered 1-time-use items - they are highly stressed. But replace all 4 WITH NEW SCHNORR WASHERS. All the usual suspects will have those. Also check to make sure it's actually the bolt and not the transmission flange that's stripped. If it's the flange you have a bigger but still manageable problem.
All these questions have been answered here many times - search is your friend. Sometimes it's a hard to get along with friend, but learn its quirks and you will be rewarded.
