I bought my '74 2.0 with a Weber progressive carb. It's in my plans to switch to dual carbs, probably next fall/winter.
I don't know for certain but I suspect that the Cam is for carbs, not stock.
From what I've gathered, 40mm carbs are the right size for a 2.0 motor for street use. Right?
I get the feeling that my top choices, in order, are:
Dellorto 40mm
Weber IDF (Italian-made) 40mm
Others? EMPI (modern version of Weber)? Solex?
I'm curious to other's input on what to look for and what to avoid.
Final question: If I buy a complete setup from classifieds on thesamba, will it fit a 914 2.0? (Intakes and all)
Since I've already got the single carb, I presume my low-pressure fuel pump will be appropriate with duals as well...
