QUOTE(mpoffers @ May 21 2010, 08:18 AM)
That's very cool. Is there any way to run a small version directly on my desktop?
Download this file
http://club914.fr/914watch.zipUnzip and put the folder wherever you want
This works on WinXP but should also work on Vista and Seven
1- Right click on your desktop of your computer and select Properties.
2- In the Display Properties box that appears select the Desktop tab and Customize Desktop…
3- In the new Desktop Items dialog select the "Web" tab then "New".
4- Now you can enter the path to "914watch.htm" file. Use the browse button to find the file.
5- At this time "Lock desktop items" button must be unchecked.
6- Apply. The item will then appears on your desktop background.
7- Click on the items border to move and resize the window however you like.
8- Once the item is in the right position you can return to the active desktop setup and check the "Lock desktop items" button
Note for advanced users:
You can change the size of the watch when editing the 914watch.htm file with the notepad.
