I've got a '74 2.0 and am now getting it ready for fist show of the season. The windshieled wipers worked fine last fall when I parked it but don't now for some reason. I did restore the dash & instruments over the winter including cleaning up the heat/defrost controls, installing a push-button start switch (key switch was unreliable in crank position), and installed a MOMO wheel w/hub.
The connections at the wiper motor, fuse block, and bottom of stalk switch are all solid.
I get no power at the wiper motor connection with key on and wiper switch on.
Could this be a dead spot in the wiper motor OR poor contacts in the stalk switch?
I dread pulling those stalk switches from the column.
Hoping for something simple.
OTHER IDEAS?
CHARLIE
