Mueller
Apr 4 2004, 02:59 PM
I thought I've seen this modification before on here, but I cannot find the pictures.
On my car the pass. side sheetmetal was hacked for an A/C installation. I'm debating repairing it or removing it completely.
Since my engine tin will be cut and trimmed as well, I don't see any real reason to keep the sheetmetal on the sides
McMark
Apr 4 2004, 03:15 PM
It's not very difficult to remove that piece. A few spot welds and some well placed cut with a cut-off wheel and it's gone.
dmenche914
Apr 4 2004, 03:38 PM
Mike: i replaced an engine shelf once, was not too difficult with a MIG welder. If you run an aircooled motor (either 6 or 4 banger) the shelf need be sealed, either with a new shelf, or some sort of patch, else the cooling fan will draw hot air from under the car. If you add a water pumper engine, then it is only cosmetics that are a concern.
I found with a VW (kit car) a huge temp difference with verses without all the stock cooling tin that seals the engine compartment, something on the order of at least 50F head temp, and simular on oil temps.
HPH probably can get you a new part, or maybe even one from a parted out car for less money.
By the way, how is the 1.8 engine? hope it is working good for you. let me know
dave menche
bernbomb914
Apr 4 2004, 04:37 PM
restoration design has a piece to replace that piece it is not diffecult to do, look at my earless piece for pics.
Bernie
bernbomb914
Apr 4 2004, 04:40 PM
xx
Jeroen
Apr 4 2004, 05:24 PM
Here's one...
cheers,
Jeroen
Korijo
Apr 4 2004, 06:48 PM
Heres mine removed...
and replaced. battery will be moved...
Chris914n6
Apr 4 2004, 11:22 PM
My favorite site
there's a few from different angles in a bland primer.
Chris
