The authenticity of this part needs verification. I have included this cable due to the brass construction and the cast in - symbol, which seem to indicate authenticity.
There is another part number listed in the PET for 70-73 cars. I suspect this early cable is of the braided variety.
The length of the cable is ~9" and is ~2AWG cable. It has a black outer coating.
The battery clamp is cast of bronze/brass and has a - cast in. The cable is inserted into a ~6.75mm hole and soldered into place. There appears to be some crimping as well. One 'finger' has a squared off edge to keep the pinch bolt from turning, the other 'finger' has a large round edge to allow for the nut and wrench.
The pinch bolt in the sample has a roughly 12.5mm x 12.5mm square head ~4.5mm thick. The threads are ~30mm long and are 8mm x 1.25. I suspect the pinch bolt was zinc plated originally, but have no evidence.
