QUOTE(detoxcowboy @ May 22 2010, 06:19 PM)
size, m4 available at ACE in SS.. take one OEM with you to double check the length and width and pitch.. and what I do is find a nut that fits the OEM to ensure choosing the right SS replacements for all and any bolt nut ect. ensuring not only width but thread pitch on the car, then you can visually compare lengths there are a couple of "VW" bolts that have a different thread pitch than you can get at Ace, but it is a rareity, and most thread pitches are standard and tyhe larger bolts usally have 2 pitches to choose from but not so with the M6 and smaller.. .. For the headlight retaing screw we are talking about I use the M4 "Allen Heads" in Stainless Steel.. Also I have been to many different aAce's and generally they car more or less same same base of either SS or Hardened Metrics. But some also have differnt selection available in metric's even Automotive such as cyl;inder head exhaust hanger bolt's or CadPlated lIcense Plate Screws in Metric..
M4 is the 4mm ect. M6=6mm and M8=8mm ect ect..
Excellent response thank you. I like the idea of Allen head vs. phillips screw head much better tool engagement. I was guessing it was near a 4mm but wasn't sure. To be honest I didn't re,ember them being machine thread I thought they were like a sheet metal thread. I will take one with me as you suggested.
