Gotcha. I have 3" spacing on the caliper mounts. I'm attempting the new strut right now (tapered pin). The entrance/exit holes on either side of the strut seems to be the same size. I took the old pin and tapped it in from either end. Either direction seems to be a nice tight fit. In the drawings I've seen, the nut seems to be on the forward end of the strut, right?
QUOTE(Cap'n Krusty @ May 29 2010, 12:42 PM)
Actually, Slits be wrong. You clean the threads with a thread chaser. It will remove only the barest minimum of metal, and will (more or less) reform the threads. The less metal removed the better chance you have of ending up with usable threads.
As for drilling the hole straight, you come in from the unthreaded side and you'll have the correct alignment for the insert.
As for the caliper mounting spacing, you measure the centerline of the 2 mounting holes, or the corresponding edges, which is easier.
HOWEVER, and I've said this before, you MUST check the fit of the ball joint BEFORE you spend any time trying to fix the bolt hole. If the joint drops right in after any burrs are removed, the strut is junk. The ball joint will be loose in there no matter how hard you wish it weren't. There is NO FIX. Well, maybe you could get it metal sprayed and bored to size, but you could probably buy a brand new strut for less money.
The Cap'n
