1975 1.8L with original fuel injection. I have totally gone over the car during the past year, replacing everything that needed replacing. I pulled the engine to repair some rust along the bottom of the engine compartment. I replaced the old plastic lines with new stainless lines in the tunnel, all new rubber fuel hoses, and filter, the PO had just installed a new fuel pump just before I bought the car. I drove it home and it ran fine. It starts with a blast of starting fluid, runs for a few seconds and dies. I can hear the fuel pump turn on and stop when I turn the key. I loosened the outlet line on the fuel pump and there was gas. I removed the fuel hose from the U shaped tube going to the injectors and there was no gas. Just to be shure I did not switch the inlet line with the return line, I used a Mighty Vac and was able to suck gas out of the line.
It seems the pump is not pumping when the car is starting, I should have had gas at the inlet line in the engine compartment???
How many turns out for the idle adjustment screw in the throttle body???
Help! It is finally off the jack stands and I want to get this car on the road!
