QUOTE(SirAndy @ May 25 2010, 10:44 PM)
I never had to do this. Ever.
How far did you tap in the corrugated bushing when it was coming out again?
It needs to be tapped in almost all the way.
I never had one coming out by itself ...
Andy
Mike installed it the first time, when he rebuilt my steering column back in - what - 2007? Then it popped out while i was driving and hit a series of bumps (PA roads are oh so grand).
So I went and tapped it back in with a hammer and screwdriver. Tapped it as far as it would go until it started to deform. lasted for a few months, until i was driving to Hershey last month. Hit more PA roadbumps (also just called I-83) and it popped out again.
Damn Zach your gauges also moved around. It must be a alien magnetic field that you passed through or you parked it too close to the jeep.
I have a smaller then stock steering wheel. They are clocked so that i can see them. Fairly common.
I cant wait to see this in person. I havent had time to pay attention to you (sorry honey). I guess this will be another mystery to solve when I come over this weekend. rolleyes.gif
Heh. It will work, keep the bushing from popping out when I hit rough roads. Hopefully the only things we have to do this weekend will be weld up stuff for your bus and cook meat on the grill. I'm going to pick up the stock tonight after I go meet my new niece.
Bearing coming out ?? Maybe the snapring that holds the bearing in the turnsgnl / wiper switch housing is missing ?? That is what holds the bearing in , not the bushing .The bushing goes down inside the inner race of the bearing around the shaft taking up the play between the shaft and the bearing inner race. Check to see if the snapring is missing and there is indeed a grove for the snap ring , it could have broke off / chipped.
I am 90% sure I say the circlip holding the bearing in place. but i will be able to check that again tonight.
Zach
