QUOTE(fitzm1 @ May 24 2010, 03:36 PM)
I have carbs with this vent box. Vents from the crank case and cylinder heads. Has no filter just a small amount of oil in bottom of box.
The box is supposed to be mounted higher (so the oil can drain back) and open to the environment.
The top should not seal, it's supposed to have a lip on the underside that prevents it from sealing the box when screwed down.
The box also should have a sponge inside to trap the oil vapors so they can condense back into oil and accumulate at the bottom, then drain back.
Make sure that box has not been sealed ...
Andy
