Here's another perspective on LEDs on crs - paticularly classics like our 914s - as someone who once considered being an auto designer back in my youth (during the stone ages), I look at the LEDs & see groups, rings or strings of tiny lights in the cars with LED lights (they're directional, so the wider reflectors in the housings on older cars don't do squat) -
... rather than a light in the shape which defines the rear end of the car the way the original designers envisioned it. In the case of our 914s - they have wide rectangular taillights which "define" the wide & low look of our 914s - which the dots do not do at all!
As to paying $12 or $50+ for LED bulb sets in a car set up to run the incandescent voltages/amps, I have to ask why!!??
... I mean really - it's not like you're being "green" & saving energy, because that alternator is running with the engine all the time anyway, & if operating properly it isn't suffering from overdraw!
... okay, so if yours is an EV-914 use them, or that one time where your alternator fails on the road, then the LEDs may extend the battery life a few minutes - but the spark is the main draw then anyway by a long shot!
They're really not that much more effective in lighting than our OE taillights with the proper bulbs & reflectors in good shape - esp. past 70-90 degrees - since 130 degrees is your cut off & that's reduced significantly from dead on up to 60-70 degrees, when it falls off progressively from there.
LEDs make some sense in building & roadway applications drawing on the power grid, but won't even make sense there until they get far more reasonable in price IMHO - which is why they're still early adopter stage overpriced items even there.
So I have to say why do it on homes & offices today - let alone cars!!??
