QUOTE(trekkor @ Apr 4 2004, 10:40 PM)
I'm looking for a replacement bulb that actually does something.
The bulbs in there just don't cut it.
Are there high output bulbs that are a direct swap?
the factory made just two kinds of aux lights -- the rare driving light that came on with the high beams. my Euro /6 had these, they are quite bright indeed.
everything else is the fog light, originally designed to operate with the low beams, although this function has been modified 'in the field' just about every way imaginable. the 'issue' with these is not the bulbs, but the wide flat-topped beam (and probably the sandblasted lanses...) is designed to be effective in fog - not light up the night. nothing you do with just bulbs is going to have much effect.
if you want driving lights, you're going to have to buy driving lights. i wouldn't be holding out for factory parts...
i don't know of a bulb-only upgrade for the factory fog lights, but like i said - it wouldn't help much anyway.
