QUOTE(Colorado_Doug @ Apr 5 2004, 04:49 AM)
About a week ago my idle went crazy. The warm up is at 3500 RPM then drops to 2200 after that. I tried adjusting the idle screw. It had no effect.
classic symptom of the Auxilary Air Regulator (AAR) failing open - or the air line leading to it cracking or just plain breaking off. sometimes the wire that powers the heater gets wonky too - check it carefully - that circuit powers the fuel pump too.
other vacuum leaks can cause this but most are too small to have this kind of effect. but where there's one, there are usually others, so check 'em all.
the idle screw on the control box affects IDLE MIXTURE only. it does not work off idle, and it does not control speed - except to the extent that bad mixture will adversely affect speed...
good luck - and welcome !
