I finally got my motor in and have the car running and was wondering at what temp does the motor normally run at when idling? I don't have the center console with a temp gauge and the car has a carb so all of the fuel injection was removed. I see the CHT sensor wire and was wondering if this can be used with some type of a gauge. I installed a new thermostat and made sure the two air flaps were in place and working on the fan shroud when I had the motor out. All engine tin is in place . I did purchase a laser temp sensor so I can try to take a reading on the engine when it's idling in the garage. What is the best set up to monitor the engine? Oil pressure, Oil temp or cylinder head temp?
Thanks for the help!
Jsaum
