Fast Original 914-6 FOR SALE
My Street legal Original 914-6 Race Car is For Sale. The car is an original 1970 914-6
VIN# 9140430940. Now is a very fast914. CA/AZ car with no rust. It weighs in at 2230 Lbs. It has a 3.2 with 275 injected HP and a side shifter 915 gear box with LSD, factory transmission cooler pump, and large Trans cooler mounted in the rear trunk. Welded in cage that’s tided to all four shock towers. Strut braces in the rear. Stock rear sway bar and a 27mm front adjustable sway bar. Front torsion bars are 23mm. Large front oil cooler. I have never seen any oil temp above 220 F even in 110 F ambient temps. The front brakes have been converted to 944 Turbo brakes and are cooled with two inch hoses through a GT Front bumper. The rear brakes have Bremtek calipers. The car has Patrick Motor Sport’s rear toe braces. The full chassis has a stiffening kit. It also has a bump steer kit. It is running adjustable Koni shocks all around. It sits on 16” 7 & 8’s 225-50 and 255-55 Toyo RA-1 and a second set on Kumho Victoracers. The battery is mounted in the front trunk behind the oil cooler.
The car is located with me in Phoenix, AZ. $28,500
Tim Hannum
Thannum@cox.net
C 602-377-4186
