This is an assembled GA long block with flywheel. I have other engine part to go with it it needed.
This engine came from a car that showed 93,000 on the speedo. Has had at least one valve job but the heads plenty of metal for fly cutting. Seems that the FI engine had some mis-matched parts that made it run rich. Was parked in 2002. Turns over by hand with resistance. Some scoring if the cylinder wall was visible through the spark plug hole. Should be considered a core engine. Available for pick up in Riverside CA or can deliver in the Socal area for gas money. Having trouble getting pictures posted. Can send them by email as requested.
Bruce
