Over the winter, I have been making some changes to my engine. Over the past week, I have been making the final adjustments and getting everything ready to go. I had the car fairly well tuned a few days ago except for one major problem, when the engine is hot, the rpm's stay high and will not go down. Because of the rpm issue, I decided to make a few carb related adjustments. . Now my car won't start. Heres the scenario-
I have a 2.3l with dual weber 40idfs. I have a bell crank carb linkage. I took the carb link off one side to set the idle. The engine had been running for awhile. I accidentally hit the carb linkage and the RPM's went to about 3k and would not come down eventhough the carbs had returned to idle. After about 20 seconds the rpms came down to the point where the engine was about to stall so I reved the engine (forgetting that I had only one carb link hooked up) to get the rpms up. The rpms went up then when I let off the throttle, the engine died. Now the car will not start.
I let the car cool for about 2 hours thinking that I may have flooded the engine however the car still will not start. THe starter turns the engine ok. The fuel pump runs. It seems like I am not getting fuel or spark. The fuel pump is running so I assume I am getting fuel. I am using a pertronix unit. I have had issues with fried pertronix units in the past so I tested it and it seems fine. I checked the coil and it is fine. I am running a MSD 6al. I understand that they fry fairly easily so when I installed it I installed it with their capacitor so hopefully it wouldnt fry.
Any ideas on why the car wouldn't start. Also any ideas on why the rpms stay up when the engine is hot?
If somebody know the reason for this, I would be greatly appreciative for your help. I would also be very appreciative for guesses.
Thanks!
