Hey rickthejetman,
Thanks for he explanation. I agree, with your application, side scoops would be a very good thing. I attached a couple photos I had, but will take some close-up shots with reference rulers to gage the size.
I have a question for you: how are you planning to flow the air through the engine bay with the Subi? I learned that my water-cooled Chevy STILL was 30% aircooled.
For the Chevy, I'm taking the air from under the car and running it UP through the engine bay and out to top. Thus feeding from a somewhat high pressure area up to the low-pressure area behind the notch roofline. To prevent the air going around the car back into the engine bay, I installed a 2" tall aluminum lip on the front edge of the lid. The more I've done to promote this airflow, the cooler the engine runs.
Another question: are you mounting the radiator in the front trunk or rear trunk?
I learned the hard way the exhausting out the bottom of the front trunk was not very efficient and blocked air flow back to the engine bay.
The absolute best exhaust flow is out the top of the hood and when I finally made that change, I was amazed at how much cooler the engine ran.
I have never liked the idea of exhausting the radiator through the fender wells : the wheels turn creating a lot of turbulence and inefficient air flow . However, with the 300 HP from the Subi, it should work fine. I have a bigger challenge cooling 500 HP.
I'm envious of the resources you have available to you. With carbon fiber, you should only need to make bucks the right shape and wrap them with the carbon fiber/resin fabric. Is should be a lot less work than fiber glassing. Do you know anyone with a CAD to prototype system?
Best of luck with your project. I'm guessing you have all the training and experience to do a very nice job of it.
Terry
Hey rickthejetman,
-well as far as the airflow through the engine bay that all depends on what i do with the intercooler set up. i was thinking of a sidemount if i do that the air will have to exit the engine bay lid. if i go with a stock type intercooler (air to air behind the engine over the trans) i was going to have it vent out the rear deck lid(i don't have a trunk anymore). option c was an air to water with the exchanger either side mount or all the way back up to the front trunk. then the engine bay would agian just have to exit the engine lid.
==> FYI: On my car I have 2 oilcoolers w/ a fan each stacked next to the left side scoop, so I would think your intercooler w/ fan could do the same, if you choose. Plan B: if you decide on exhausting out the trunk, I hope I have an idea for you: My V8 has a big bundle of snakes exhaust called "180 degree headers" that live about 1/2 in the trunk. Most of the trunk interior is cut out to fit. I have a lot of heat under the trunk lid and found that by propping the trunk lid open about 3/4", I can move a lot of air out of the trunk. The best part is that is doesn't show!
I just adjusted the latch higher and screwed down the corner rubber bumpers to match. Since mine is 90% track car, I cheerfully cut and chop as needed, but I'm thinking yours might be a daily driver. so how will you channel air INTO the trunk?-as far as the radiator its in the front trunk its gooing to exit the hood ala gt40 style. i have a friend that tells me we can make hood louvers from composites as well. that might be pretty trick if they flow the lines of the triangular hood suppport.
==> PERFECT! It easy to cut out the hood and well defined by the hood supports. I made louver slats from aluminum to keep the large birds out, why AndyS installed a nice open-mesh screen in his....it's all good!-i'm still in the early stages of my build so i havent got everything figured out yet.
i didnt like the idea of venting under the car either all thou it seems to work well on my mr2.
==> It works well for me with all the engine I have. After a drive I find dust all over the trunk lid and SMILE: Ah good airflow!a-s luck has it i came across an oil to water cooler in the trash it was left
over from an R&D project at work the other day. if i can get that plumbed into my hard lines going up front that would be the ultimate setup. very minimal pressure/flow loss no need for an oil t-stat. very clean install.
==> Great type of oil cooler. If you can make it work, go for it!-as far as skills with composites mine are really only based in airframe repair. im not so skilled in fabwork. but i have a few friends in the production side of life that owe me favors. if it burns fuel i can fix it/ build it/ make it better. if it involves fabwork/ bodywork i get by with a little help from my friends.
==> Great friends to have!! Have you mentioned body panels yet?-i appreciate you sharing yourscoop pics with me. i have been kicking around a few ideas then i ran into yours and those look very clean/trick on the 914 almost factory race style.
==> I took a couple more pics and with my camera, just couldn't get the steel rulers to be readable. So check out the photos and let me explain that front to back in the middle of the scoops they are 9" while top to bottom is 11". As I said,
I laid out a basic outline on surfboard foam and then started hand shaping. It's a burn to realize that 2 molds are needed! If I can be of any other help, let me know,
Terry
