Type 47
Jun 3 2010, 11:19 PM
Just got a 75 2.0 that has had dual Webbers replace the fule injection...
Do carb conversions require a different cam?
do just bolting on carbs do the trick?
VaccaRabite
Jun 4 2010, 06:02 AM
Carbs require a different cam to run *at their best*. But the car will run on the stock cam using dual carbs. You will just be leaving power on the table.
Zach
ME733
Jun 4 2010, 07:29 AM
.As you just got the car, ....sort it out first. optimize the carburator settings and jetting...for that camshaft/piston cylinder, head combination...optimize the ignition timing...the "OEM" stock camshaft works with fuel injection, and will work just fine with carburators with a little tuning.Carburator CAMS will have more duration,(and generally) more lift, which is why they work better,produce more H.P., and at higher rpms........optimize what you have first.
tat2dphreak
Jun 4 2010, 09:25 AM
