Hi guys
For those that don't know me, I rally a 914-4 1973 in historic rallying over here in the UK. I've gone through 2 rear ball cup linkage things in the past 2 years. The latest failure (today) forced us to retire from this weekends rally, a real dissapointment as we were really peddling fast.
I've got a full on Rennshift system, so the only non bronze bushing between the bottom of the shifter and the shifter fork on the gearbox is the plastic ball cup thing at the rear (kinda the weak link). The previous one that I replaced last year was a new one at the start of the year, but by the end of the season it had cracks on it in the usual places and was ready to let go. I then put on a good secondhand one I had lying about, which completely disintegrated today, which meant I couldn't get it into any gear - rally over
Another thing to keep in mind hear is that with rallying it ALOT more stressfull on the linkage than any Auto-X or circuit racing due to the amount of shifts e.g. quite often 2 shifts down, 2 shifts back up for every corner, 50 corners per stage, 7 stages per rally. Then throw in dust and dirt constantly at everything that moves and has oil/grease on it, and to make matters worse there's an additional heat issue as we run a big skid-plate on the rear so all that heat from the exhaust has a LOT less air flow to dissapate the heat.
SO what I'm saying is that this plastic part gets a lot of grief, a lot of heat, a lot of dirt. If this part ends up being a throw away part after each rally I can accept that, I was wondering if anyone knows of a bronze version or some other upgrades people have experience with?
Thanks in advance for any pointers
