New rotors, rebuilt calipers, new lines, a motiv power bleeder and 192 oz of brake fluid later I still have a soft brake pedal.
I've tried cracking the lines at the master cylinder and at the proportioning valve. I've tapped on 'em too, as I'm pushing fluid through the bleeder valves. I've carefully taken the car through a parking lot just to try and move any air that might be trapped in a hight spot. I don't get any air bubbles when bleeding any of the lines.
Rear venting clearance is set to .004. I didn't adjust the brake pedal piston rod because the brakes worked before I replaced them and the manual isn't clear about how to do this.
Started to think that maybe the master cylinder is bad, but the pedal can be pumped several times to get a *somewhat* firm pedal, and it holds, so maybe the master cylinder is ok?
Started thinking about trying the 'long tubes' method to bleed the system, but if I don't see any air coming out of the lines now, what's the point?
Is there something I'm missing?
