[quote name='scotty b' date='Jun 6 2010, 02:54 PM' post='1328883']
[quote name='KELTY360' date='Jun 6 2010, 01:27 PM' post='1328877']
--><div class='quotetop'>QUOTE(scotty b @ Jun 6 2010, 02:18 PM)
</div><div class='quotemain'><!--quotec-->
Did you set the end play?
[/quote]
No. I removed one flywheel and bolted another one on. How do I set the end play?
[/quote]
Shims go inbetween the crank end and the flywheel. This alllows for a specified amount of front to rear movement of the crank. Without the proper amount you can end up with a binding engine, or too much slop. You need to find out what the specified amount is, get the appropriate shims and set it up. All it requires is a dial indicator mounted to the case, measuring the flywheels movement. There are some threads here going through the proceedure.
[/quote]
that 'splains it
