moparrob
Jun 6 2010, 06:04 PM
I just picked up a used interior rear view mirror in nice shape, except the pivot ball mechanism is loose so that the mirror wobbles around. Is there any easy way to tighten these up?
Thanks.
McMark
Jun 6 2010, 08:16 PM
Not that I know of.
The stock mirrors have a removable base, and that screw can come loose, but that's not the problem you said you're having.
moparrob
Jun 6 2010, 08:53 PM
It seems as though you should be able to pull the ball out of the socket, insert some friction material to take up the loose space in the joint (ie electrical tape?) and push the assembly back together, no?
McMark
Jun 6 2010, 10:07 PM
I say nope, but it's your mirror. Give it a shot.
nsr-jamie
Jun 7 2010, 08:25 AM
Can you use the new mirror with your old base? One single screw connects them together...you should also make sure they are tight to begin with just in case
EdwardBlume
Jun 7 2010, 08:30 AM
I had this problem on my old street / ax car and I just learned to grab it and look back at the same time. You might try butyl.
moparrob
Jun 7 2010, 10:08 AM
Well, it seems as though my quick fix has worked - at least for now. I used two 1/4 wide strips of electrical tape in the socket, overlapped in a basket weave fashion. It was difficult to push the ball back into the socket, but once it snapped in it now has a pretty decent feel to it. Try it and recycle an old mirror..
carr914
Jun 7 2010, 10:36 AM
What is behind you is of no importance - throw that thing away
EdwardBlume
Jun 7 2010, 10:52 AM
QUOTE(carr914 @ Jun 7 2010, 09:36 AM)
Thats why our butts are facing that direction
