Ok fuel injection guru's I need some guidance.
I picked up my car this weekend and everything is great runs like a top pulls strong ect. However I must have a vaccum leak (idle surging) Im going to take a propane tank to it tonight to see if I can find the leak. Got the diagram for a 1.8 off of the pelican sight and was having problems tracing vac lines. My question is I have a 1975 1.8 from what I glean this should be a L-Jet car or am I mistaken? I have never worked with analog FI but when I look at the components I swear I have a Mass Pressure sensor (MPS) siting on the passenger side of the engine bay. MPS is for D-Jet systems or do both L-Jet and D-Jet have a MPS. I though L-Jet was a MAF?
The car had a engine rebuild in 2003 paperwork has 1.7 so the car may have had a different engine or the shop could have written down the wrong number any way to tell by looking?.
Anyways I would appreciate it if someone cleaned up my confusion
Ill post pics this evening when I get home from work.
Also thoughts on removing EGR? I don't need one in ohio should I remove it and potential vac leas associated or just change the vac lines when i change all the others and be good to go.
Thanks all for the help
