QUOTE(motomadness1947 @ Jun 7 2010, 01:37 PM)
I recently bought a 914 2.0 fI from a fellow named Rube Goldberg. He has relocated the fuel pump and filter under the car just behind the steering rack and pinion. I have read several places about relocating these items but it just says to relocated them to the front but does not say were they were or where they are going. He used rubber hoses and put such close bends in them, I am sure they are cutting off flow.
Would someone please post a picture of the correct relocation place and provide other pertinent information that may be relevant. Thank you
That is in fact the correct factory recommended relocation point for the pre-75/76 MY 914s (when they later put it up front), but specifically for the 70-74 914's - where there is an access port for hoses & protection by the steering rack's cover pan, but allowing access to repair/replace pump &/or lines & easily replace filters. Not a Rube Godberg project at all, unless it's poorly done!
I had mine done by my factory trained 914 mechanic in the late 1970's per the factory bulletin to resolve the infamous vapor lock problem with the pump in the hot engine compartment below the battery area. When done properly the lines won't be kinked, & power is usually run along behind the passenger side rocker cover using the holes in the sill braces to support them (unless the AC lines are running there on an AC'ed 914).
fyi - AA sells a kit with all you need, it you want to refresh yours & ease the bends in those lines which you feel are too tight (mine aren't, but don't see a pic of yours to judge).
QUOTE(vsg914 @ Jun 7 2010, 01:41 PM)
If there is a "correct relocation place" it would be under the tank like the 75/76's
Absolutely not - what are you going to do, pull the gas tank every time you need to check or work on fuel lines/hoses? - or cut into the front trunk bulkhead to create a new area to rust? Underneath behind the steering rack is where the factory issued a service bulletin for relocation & provided a parts kit with which to do so (similar to AA's current kit).
Here's a pic of my circa 1978 relocation per the factory recco (excuse the dirt & rust, but the poor old gal has sat on blocks in my garage for the past 25 years awaiting my attention).
Click to view attachmentClick to view attachmentHope this helps - Have at it!
