Wondering if anybody has used this:
no-weld O2 sensor mount
It's a clamp with O2 sensor socket and hi-temp gasket. I may be wanting to use an
O2 sensor for some carb tuning of the -6, but am not going to cut into the heat
exchangers. I would want to put this in the tail pipe of the muffler. Is that going to
work reasonably well or do you need to be closer to the heads?
Thanks
