Teknon
Jun 13 2010, 04:02 PM
Do we have a list of the light bulbs that are used in our cars?
Somebody must have categorize it im sure.
I can not find it, in any source I have. I'm especially concerned with the truck light.
underthetire
Jun 13 2010, 04:09 PM
JeffBowlsby
Jun 13 2010, 04:32 PM
Here is my list, mostly complete:
underthetire
Jun 13 2010, 04:46 PM
QUOTE(Jeff Bowlsby @ Jun 13 2010, 03:32 PM)
Well that one need to be in the Faq or classic section! Well done.
underthetire
Jun 13 2010, 04:54 PM
Although, I do see an error or two, the 1157's and 1156's cross over the same, 1156,and 1157's. Just FYI.
JeffBowlsby
Jun 13 2010, 04:55 PM
This and other tech references can be found here:
http://bowlsby.net/914/Classic/TechNotebook.htm
Teknon
Jun 13 2010, 05:37 PM
WOW
Incredible, thanks so much!
Tom_T
Jun 14 2010, 02:28 AM
QUOTE(Jeff Bowlsby @ Jun 13 2010, 03:55 PM)
http://bowlsby.net/914/Classic/TechNotebook.htm Also in your owners manual
IMHO use caution to not use larger wattage bulbs than listed in the owners manual, because at least they'll melt/warp your plastic lenses/housings, at worst may be fire hazard. Many parts suppliers will try to sell you "bigger" bulbs cuz they're supposedly better or brighter, when in fact they just don't have/carry the proper ones!
buhs914
Jun 14 2010, 03:17 AM
QUOTE(Tom_T @ Jun 14 2010, 01:28 AM)
or you could get the LED replacements and have lower heat and won't have to worry about warping!
type47
Jun 14 2010, 05:31 AM
Auto Atlanta catalog has a good list of bulbs too.
McMark
Jun 14 2010, 10:35 PM
Another tid-bit, having incorrect resistances will cause your turn signal indicators (in the tach) to both flash, instead or just the left or just the right. Using the correct bulbs and with clean connectors and grounds should make the indicators work correctly.
