QUOTE(tod914 @ Jun 14 2010, 01:26 PM)
Thanks guys. Tom where does the relay go? Do you have to splice wires?
Yes spliced-in & IIRC the relay is up front wherever you want to hide it for your CdE events (behind headlight box under motor was where I planned to hide it). Instructions come with the relay kit & the H4 upgrade is in the factory service manual later service bulletins/updates (for after the US approved them).
You'll need the Hella H4 US conversion housings (maybe Bosch) & DOT approved bulbs (or ignore DOT on bulbs) at 55/65w & add the relay kits if going higher like 80/100w bulbs. So long as the housing is correct, you can probably get away with non-DOT 80/100w high output bulbs, so long as they're properly adjusted to not blind oncoming drivers - which is pretty easy to not do being so low on 914s (who is going to look inside the housing?). It may take some searching around to find the various parts, since some suppliers aren't carrying the whole 9 yards anymore. Also you can price shop around for the best cost overall on them with the usual group of suspects.
BTW - Tod - in your "it's done pix" - it looked like you may have had the radio antenna installed at a rearward rake - or it could've been the photo. OE was to go vertical straight up if not in that way, & you just rotate the angled base & chrome hollow "cone" to get it straight up-n-down.
Underthetire - he's in "Joy-sey" - if they're limited to 55/65 there, then he'll just bribe someone!
Since most newer cars have so much brighter & higher power headlights, I think most/all states aren't worried about higher power back-dates, as they are with proper headlight beam adjustments.
