DanT
Jun 16 2010, 08:25 PM
looking for 4x130 bolt circle wheel spacers.
at least 7mm thick or thicker if you got them....preferably about 10mm
what you guys got out in the garage?
bdstone914
Jun 17 2010, 06:47 AM
Try your local retail auto part store like Kragen-O'Reily's. They have 1/4" universal bolt pattern spacers for about $20 a pair. I have a friend who is using this type on a race car to adjust the track.
http://shop.oreillyauto.com/ProductDetail....tegoryCode=3563 Bruce
blitZ
Jun 17 2010, 12:13 PM
I bought the 1/4 inch spacers from CIP1. They work well.
http://www2.cip1.com/SearchResults.asp?Cat=1263
EdwardBlume
Jun 19 2010, 08:59 AM
I have one newer 1/4 inch spacer, and I'm fairly sure I have another one, used, around here somewhere. The bolts I bought new are slightly longer, slightly longer, than the stock fuch bolts, I have seven...
DanT
Jun 19 2010, 09:11 AM
Rob, those spacers should be perfect
All I will need is two of those babies and I should be good on spacing...
My longer studs for the rear should work just fine.
How much $?
URY914
Jun 19 2010, 09:56 AM
Go to Home Dipshit and buy some 1/8' aluminum and make some.
DanT
Jun 19 2010, 11:32 AM
QUOTE(URY914 @ Jun 19 2010, 08:56 AM)
Paul, that would be great if I had access to a band saw or a lathe, which I currently do not.
URY914
Jun 19 2010, 05:19 PM
QUOTE(DanT @ Jun 19 2010, 10:32 AM)
1/8" aluminum can be cut with a $20 jigsaw with a metal cutting blade or a hacksaw.
