Those that have a 3.6 know the dilemma of using the stock front pulley....It's too big to fit. It's a stacked pulley with 3 grooves. The alternative for most people is to use the Patrick pulley that is a single groove but smaller diameter. Smaller is not desirable for a street machine in stop and go traffic and 993's are hard on valve guides so I try to avoid heat.
I discovered a 993 RS Pulley that should work for us. Stock diameter that yields stock fan speed. Pricey at about $275.00 but only slightly more than Patricks and it's steel not aluminum.
Andy and I were talking about this and I thought others might benefit as well...
I have not installed it yet and probably won't until winter but will report the results.
Part # 99310205040
