QUOTE(dr914@autoatlanta.com @ Jun 18 2010, 04:48 PM)
QUOTE(eimc @ Jun 18 2010, 07:02 AM)
I have Andy Ritters old 914-6 race car and need to know who makes the bracket on the trans for the pull type clutch. Thanks Paul
you will have to find a 70 71911 housing and side cover
Then you have to set the R&P....
Has this conversion already been done?
I checked into this totally for my /6 conversion and you need to tear down the tranny and do a mod of the pivot post. Then you have to make (or have made) a bracket and fasten it to the side cover using longer studs.
The KEP solution is way easier...about $600, comes with adapter, PP and disc...bolts right in like stock and Bob's yer uncle.
I'm assuming this is a 9 bolt flywheel to a 901, right?
