oldschool
Jun 22 2010, 12:44 AM
so my high beams stop working, fuse looks good?
EdwardBlume
Jun 22 2010, 01:27 AM
ice... + a fan?
avidfanjpl
Jun 22 2010, 01:30 AM
Jeff Bowlsby has a ton of diagrams on his sites.
I am sure you can trace out the highbeams and it may lead to a bad relay, but I am not certain.
I run mine only in daylight, but my lights do work. I just need to save up for an H4 set!
The fuses are all correct? I replaced all mine when I bought the car.
Good luck!
John
Tom
Jun 22 2010, 06:59 AM
Do you get a click when you pull the turn signal lever? If not, probably bad high/low beam (dimmer) relay. The new relays will require a jumper to work correctly. Jumper terminal 56 to 30.
Tom
TheCabinetmaker
Jun 22 2010, 07:01 AM
with Tom. headlight relay.
