So I take the 14 to work today. 40 miles each way. On the way home I hit a typical bump in the road at 70mph. BLAM!, SNAP! I heard a very loud metal breaking sound. The rear left corner of the car squatted 2 inches and the steering pulled to the right. I pulled over looked under the car from the rear I can't really see anything but I do notice the rear spring is now touching the unibody some. I popped the trucnk to see if I broke the top spring perch. Nope, looks good on top, nut is still tight on the shock top. I can't get a good look at the console yet. I'm afraid to jack it up until I get it into the garage on flat ground.
I know, I can just fix it by lowering the other 3 wheels. Then it will ride level.
So give it your best guess and I'll let you know who is the winner!
UPDATE! 6-26-10
Fixed it. The rears are Bilsteins HD. DAPO painted them shitty red. The clip for the spring perch was at the bottom of the shock still hanging on. The original grove the clip was in was worn and forced the clip to slip. I bead blasted the paint of the shocks, moved the clip to the next grove down and repainted the the appropriate yellow. So, the rear is 1/2 lower now and I lowered the front 3/4. Here is a pic of the ride height.
