Alright, very easy to make it yourself. Like what was said before, 1/4 inch
plywood , is O.K. I like basswood easier to work with , you need one for a
template. Radius all edges, fabric stores sell foam padding and the vinyl.
Glue padding to the cut out board , I do just the top ,then vinyl, make the correct cuts and glue edges to the underside.
Part of a deck of cards is good to hold the inside of the slot for the heater defrost lever. I use reg. upholstery spray glue, do 1 side at a time pulling tight and a heavy book as a weight. takes about 1/2 hr. to dry.
If you need futher help P.M. me Dave
