bandjoey
Jun 25 2010, 09:45 PM
The backup lights don't word so how can I test the switch on the transmission while it's in the transmission?
Cap'n Krusty
Jun 25 2010, 09:55 PM
Jack up the car, put it on jackstands, put the car in reverse and unplug the wires from the B/U light switch. Put an ohm meter across the terminals of the switch. If it reads continuity, the switch and the pin are good, if not, one of those 2 things is bad. Mostly it's the pin, IME. You can then pull the switch out of the tranny and push in the center and see if you get a reading. With the key on you can touch the wires together and see if the lights come on. If you have a pertronix, you'll want to have the coil unplugged for this one.
The Cap'n
bandjoey
Jun 25 2010, 10:45 PM
Thanks Cap'n. Easy test and exactly what i needed to know. Glad U don't like Italian cars.
Drums66
Jun 26 2010, 12:35 PM
QUOTE(bandjoey @ Jun 25 2010, 09:45 PM)
never met a man that did'nt like.......Ferrari,vrrrrooom!!!
bandjoey
Jun 26 2010, 01:30 PM
As long as Cap'n keeps working on 914's...
rwilner
Jun 28 2010, 05:59 AM
My reverse lights are also not working. Anyone have a pic of where this switch is located on the tranny?
AvalonFal
Jun 28 2010, 06:41 AM
QUOTE(rwilner @ Jun 28 2010, 07:59 AM)
On my '74, the switch is screwed into the trans in the bottom right part of the pic with the protective black rubber boot and the wiring.
Paul
jt914-6
Jun 28 2010, 06:42 AM
Driver's side, near CV, above side shift on '73-up/converted trannys......under boot if you still have one.....
rwilner
Jun 28 2010, 06:46 AM
Thanks gentlemen.
Paul, that is one clean looking ride!
JT -- is that a hanger for a KH header (or equivalent)?
jt914-6
Jun 28 2010, 07:07 AM
QUOTE(rwilner @ Jun 28 2010, 07:46 AM)
Thanks gentlemen.
I'm using European Racing Headers Jet Hot coated with O2's and an enrichment meter....It's a 3.0 six....
