sixers34926
Jun 26 2010, 07:12 PM
when i turn the key i only get power if the key is turned at just the right place if that makes any sense. If i turn it to crank i have no power, no light no guages, no fuel pump, no starter no nothing. has anyone ever heard or seen this? any ideas what could be faulty?
detoxcowboy
Jun 26 2010, 07:15 PM
ignition switch faulty.. they seem to crap out often enough.. the key itself turns free so I would definately try another ignition switch..
sixers34926
Jun 26 2010, 07:21 PM
QUOTE(detoxcowboy @ Jun 26 2010, 06:15 PM)
ok i was kinda leaning towards a new one. could that be the reason i cant get any power to lights and everything too?
Kirmizi
Jun 26 2010, 07:28 PM
Yes, just be sure to replace it with an OEM unit and not one of the cheapos.
Mike
sixers34926
Jun 26 2010, 07:36 PM
QUOTE(Kirmizi @ Jun 26 2010, 06:28 PM)
Mike
is the one from pelican oem?
Kirmizi
Jun 26 2010, 07:48 PM
I don't think so. I ordered my "first" replacement from them and it caused more headaches than I started with. I bought an OEM from GPR, problems solved.
Mike
sixers34926
Jun 26 2010, 08:01 PM
QUOTE(Kirmizi @ Jun 26 2010, 06:48 PM)
Mike
ok thanks for the help!
bandjoey
Jun 26 2010, 08:41 PM
You probably don't need the entire switch. It's the plastic OEM electrical part on the back of the switch that goes out. You can get that from a half dozen sources.
