solo1
Jun 28 2010, 08:59 AM
Guys I need help. I took the front left caliper off about a week ago to loosen it up as it was sticking, replaced pads. Drove the car it still got hot so the caliper is sticking. Rebuild kits arrived for all four corners. took same caliper off, pads out. Now what? if any one can give me or direct me to, a step by step way of re doing this I would really be grateful. Assume Im a "special needs" brake mechanic. I have always had some concern about brakes cause it has to be done right. I keep staring at the caliper thinking this cant be that tough have one side piston secured with a C clamp and block. Thats as far as Ive gotten. Thinking I may be in too deep and am considering taking them to a shop and having them to the re build with the fresh parts.
underthetire
Jun 28 2010, 09:14 AM
Just did mine Last weekend, Fronts are easy. Rears not so much. First thing you need to do is get the pistons out. Remove your clamp, and with compressed air blow in the brake line fitting. One piston should blow out. Split caliper and you will see the two fluid holes, one on each side. Grab the side that still has the piston in it, and clamp in in a vise with a soft piece of plastic covering one hole and the mating surface on one side. Do not gouge the machined surface! Blow air in the free hole now, and you may have to gently pry the piston out at the same time with a screwdriver. A word of caution, the piston will fly in to the front of your car and dent it if pointed towards your car
. Brake fluid will be everywhere, so be prepared. I use a brake hone to clean up the bores, just a swipe or two will do it, just to get the varnish off. Clean the pistons with 600 sandpaper, clean everything very well. Re-assemble using brake fluid only. I hope you didn't buy EBAY re-build kits, they do not have everything you need.
Rears are almost the same, but the adjusters and adjuster snap rings are a real PIA if you've never done them. And if the Ebrake arm area needs rebuilding to, might as well just send them to PMB.
solo1
Jun 28 2010, 09:28 AM
QUOTE(underthetire @ Jun 28 2010, 11:14 AM)
thank you just printed it out. did not get re build kits from ebay, got em from Pelican.
Ericv1
Jun 28 2010, 08:08 PM
QUOTE(solo1 @ Jun 28 2010, 10:59 AM)
As he said be careful when blowing the pistons out. Make sure no body parts are in the way as it will hurt. What part of Cincy you from? There's not too many teeners around here.
Eric_Shea
Jun 29 2010, 08:24 AM
***IMPORTANT***
I don't recommend anyone use Jeff's method of rebuilding a front caliper. It's very dangerous and, the screwdriver trick is what's damaged "many" 914 front pistons. (Sorry Jeff)
DO NOT seperate the caliper 1/2's before the second piston has been removed. A long steel plate the width of the cavity and a rubber washer from Lowes/McMaster-Carr is a "much" safer bet. Pad the cavity with a shop rag and blow the inner piston out first by clamping off a corner of the outer piston. Then position the rubber washer over that bore. Use the vise to clamp the bottom of the steel plate with the caliper mounting ears and a couple of c-clamps for the top. This will hold the rubber washer over the bore and seal it off. Again, pad the piston cavity so you do not break the tops of the pistons. Use air. If you need to use a screwdriver to get the piston out... don't; move to fluid at that point. A cheap grease gun from HF will work. Remove the nozzle and you will be left with a 10x1 fitting that will screw right into your caliper. Fluid does not compress and the resulting effect will be a piston that simply "plops" out onto your bench.
Air compressed in a caliper 1/2 pointing ??? in the garage can net a piston flying out of a bore at the velocity of a bullet. You decide if that's a good/safe thing.
Personally, I don't use compressed air anymore on 914 front pistons. They are too fragile. I have a special water pump made up to pump pistons out... that said, this is still something you can do at home with a grease gun. It will just be messy to clean up (use brake cleaner and compressed air).
Do not use 600 grit on your pistons. 0000 steel wool is most accessable. A bench top buffer is preferred. Those sides are a sealing surface and, you can risk mis-shaping them with too much grit. I've used 600 in the past and I agree... this is picking-nits, you can use it but go with very light pressure and wrap the 600 around the piston. It's just easier and better with the steel wool.
Wire brush on a drill is good for cleaning the tops (not the sides), then use a heat paint to coat the piston tops (muffler paint or POR-20)... brakes get hot.
Not a fan of honing bores anymore either... this leaves a fresh steel on steel surface where rust can develop. They make brake cylinder hones, I've used them in the past but, not my favorite thing moving forward.
I'm a big fan of taking these caliper 1/2's to a local plater. Usually, for around $20.00, you can go to your local plater (Google is your friend) get a fresh coat of yellow zinc, just like ATE did. The process of cleaning and etching will clean the bores and you will be left with a nice coating of zinc there. The bore is not your sealing surface... the seal and the piston is.
Hope this helps.
Krieger
Jun 29 2010, 09:00 AM
Eric, when doing a front pair of calipers do you bother getting each piston back to its original location?
underthetire
Jun 29 2010, 09:01 AM
Thats why your the "expert"!
I could see the screwdriver thing damage a piston, but with a little back pressure and a gentle nudge with the screwdriver, mine came out with zero damage. They do come out pretty fast though once they start moving.
Eric_Shea
Jun 29 2010, 09:10 AM
Absolutely. The late model kits come with positioners which I recommend you install before re-loading the pistons.
1. Clean/Restore pistons.
2. Install dust seal
3. Install positioners
4. Lubricate underside of dust seal (late model fronts only)
5. Install pistons
There's a trick for those that don't come with positioners as well. Draw an imaginary center line down the cavity and place the bottom notch of the piston step along this line. This will ensure a 20 degree alignment in the face of the on-coming rotor.
Now, if you're asking if I put the left outer piston back where it was in the caliper, etc.? No.
tat2dphreak
Jun 29 2010, 09:54 AM
or be 100% sure and just use your calipers as cores for Eric... I did this and have never regretted having 4 great looking, great stopping brakes with porterfield pads...
the car stops on a dime.
solo1
Jun 29 2010, 10:09 AM
QUOTE(Ericv1 @ Jun 28 2010, 10:08 PM)
Im in maineville actually north of kings island.
solo1
Jun 29 2010, 10:20 AM
thanks you guys will try it this weekend. taking the caliper off and disconnecting the brake line i need a fitting that goes into the brake fluid port on the caliper and attach it to the air compressor what size should the fitting be that attaches to the brake fluid port. next the seal that goes around the piston has a split ring holding the seal in place , the seal is shot will i still be able to blow out the piston? or am I "fuched"?
underthetire
Jun 29 2010, 11:13 AM
QUOTE(solo1 @ Jun 29 2010, 09:20 AM)
The split ring only holds the dust cover on. The seal is internal. I just used a blow gun with no fitting. Mine popped out pretty easy. Your re-build kit should have 2 internal piston seals, two dust covers, two metal retaining rings, 2 piston anti-rotaion shims, and a new plate with tabs for the mounting bolts. The kits I got from eric even had new mounting bolts. You may want to get the caliper o-ring seals for the body to put it back together with to, even my kits I got from eric were missing them, but he mailed them to me.
solo1
Jun 29 2010, 11:27 AM
QUOTE(underthetire @ Jun 29 2010, 01:13 PM)
i got the parts from pelican it appeared to have everything you mentioned thank you was spazzing on the outside ring being gone thought the seal was blown so there was no way to get the piston out. You guys really rock Im a newbie at this but am determined to do as much of this stuff without farming it out. seriously thanks to every one of you guys.
biggy72
Jun 29 2010, 09:05 PM
So I've got 4 VERY stuck calipers. I'm trying to get the pistons out, but nothing seems to work like it did for the people above. I haven't tried to adjust the rears out yet, but the fronts won't move. I took the dust covers off and sprayed some penetrant fluid around the pistons, but is there a good way to get them out?
Eric_Shea
Jun 29 2010, 09:24 PM
Fluid is probably the only way at this point. I know what you're saying because I see it almost daily. You can:
1. Put them back on the car and try to pump them out that way. You might be able to get them out far enough where air will work.
2. Get a cheap ($13.00) grease gun and remove the tip. You will be left with a 10x1 end that will screw into the caliper. Grease, being a fluid, will not compress and the piston will plop out. Follow the instructions above for the second bore.
3. Devise a water pump. This will be easier to clean up but more difficult to fabricate.
Tip: Not sure about the laws in WA but here on Planet Utah we can still buy the Gunk carb cleaner by the gallon. You might try soaking them in there for a couple days and try air again.
Tip: Using a large C-Clamp, push them back in. This can break the bond of piston and bore and they "might" come out with air.
Tip: You can try heating the calipers outer surface with a MAPP torch. That may also help break the bond of piston and bore and they "might" come out with air.
Tip: You might try brake cleaner around the pistons and into the fluid inlet. This may break that bond and they "might" come out.
Bottom line though... a proper fluid extraction will work wonders and keep both the caliper and piston in good order.
________________________________________________________
Regarding ther rears.... here's a few more tips:
Tip: Move the handbrake arm before attempting to remove the inner piston. Even if you have to tap it with a hammer (WATCH THE SPRING PIN AND DON'T TAP TOO HARD!!!). By moving the arm you will move the piston about 1/8th inch and break that bond and the piston should come out much easier.
Tip: Use an air wrech to power out the inner piston after you move the handle back. Watch the handle move forward, pull it back again and do it all over again. This put minimal strain on that inner adjuster. You're basically using the handbrake arm to push out the piston.
Tip: Take the clip and the 13mm locking nut off the outside adjuster and lightly tap the entire thing out. Use a plastic mallet if possible so as not to distort the 4mm hex. Once the hex becomes flush with the caliper, use a 4mm bit and bring it back up to the top. Rinse and repeat. This will literally tap the piston out without damaging the fragile 4mm hex (unless you wack it too hard)
Did I mention that fluid is probably the only option at this point?
They can be saved.
biggy72
Jun 29 2010, 10:52 PM
I tried some heat tonight. I got the inners pushed most of the way out on the rear, but I'll have to give the e-brake arm a try.
I'll try tapping on the outters for the rear. I had it pushed out, but it wasn't going anywhere. I guess I didnt' see that it should be tapped in and done over again.
I'll also give the grease gun a shot tomorrow. I figured I couldn't be the first person that couldn't get the pistons out that easy, but it seems like most of the people I read about just have them slide right out.
Thanks for the help
Eric_Shea
Jun 30 2010, 07:27 AM
If they're pushed most of the way, they are probably off the adjusters now. You may be able to rock them out. I have special cutouts in the ends of my vise to grab the piston head without damaging the dust seal ridges.
If the caliper is working on the car at the time of removal/restoration they generally just pop right out using air. If the car has sat for a long period of time... most are in your boat.
NOTE: Do not use fluid or air on the rears. They simply adjust out. Only in extreme cases have I used fluid on the rears and this is to literally blow the piston off the internal adjusting mechanism. This is only when the inner adjuster does not turn using the gear... very extreme and rare circumstances and very extreme measure. ONLY USE FLUID AND AIR ON YOUR FRONT CALIPERS.
solo1
Jun 30 2010, 08:16 AM
consider me brain dead. spent a while working on caliper last night to blow out the piston. First used a block of wood and C clamps to apply pressure to move piston in and out make sure it wasnt seized, they flexed a little bit not sure how much movement should be in there.
newbie question: how do i block the bleeder valve or the bleeder valve hole to prevent the pressurized air from escaping? should this be this difficult or am i just encountering newbie-itis?
Mikey914
Jun 30 2010, 08:20 AM
Eric did a rebuild demo at WCR, it quickly was apparent that if your doing a single set of your own, it was probably much easier to just send him a core set and swap them out.
solo1
Jun 30 2010, 08:40 AM
QUOTE(Mikey914 @ Jun 30 2010, 10:20 AM)
eric shea in UTAH? got an e mail or contact number, thanks
BigDBass
Jun 30 2010, 08:51 AM
QUOTE(solo1 @ Jun 30 2010, 09:40 AM)
Can PM him through his post a couple above yours, or get to his website via the link in his sig: www.pmbperformance.com
By the way, I agree, just send in your cores and get some of his rebuilts. That was my first 914 parts purchase and project after I got my car! Eric rocks.
Eric_Shea
Jun 30 2010, 04:08 PM
Thanks Dan!
Ummm... do I have to be the one to say "put a bleeder valve in it"?
underthetire
Jun 30 2010, 04:20 PM
QUOTE(Eric_Shea @ Jun 30 2010, 03:08 PM)
Thanks Dan!
Yes, I wasn't gonna do it. I figured if he had to ask that question I didn't want to be in front of that car at a stop light. Thats why your the Masterbraker
biggy72
Jun 30 2010, 10:53 PM
I got two of the calipers completely apart tonight with the grease gun method. Worked really well.
On the other front caliper One piston popped out easily, the other slid most of the way out and then I can't get it to budge the last little bit for anything. On the other rear caliper the adjusters were messed with and they both seem to be broken. I can't get the lock nut off because the thread on the screw is all stripped off and the adjuster on the other side just spins.
Eric_Shea
Jul 1 2010, 11:43 AM
It is cocked in the bore (all you "Juvies" are now free to flail away on that one). You need to take a close look at it to determine which way it's angled, then use a c-clamp to snap down the high side. I say "snap" because it will kinda "pop" or "snap" when it goes back into alignment. Do that and try again.
OK... couple of options here:
1. Use a high speed wrench and a 4mm hex to power those things out. Remember - Counter Clockwise. They should move right out with speed.
2. (You'll probably have to do this anyway) Take a Dremel and a Carbide Cut-Off Wheel and cut "straight down" through the "center" of the adjuster and 13mm hex. Make sure you're on center so the cut-off wheel doesn't score your caliper. You can ease over to one side or the other to get a decent slice on the 13mm nut.
Make sure you do not go through to the caliper surface or that adjuster bore. Then, when you're almost through, finish it off with a sharp cold chisel. Remove the pieces of the nut and push the adjuster through. I can replace both those parts for $20.00 if you go that route.
3. If the threads aren't too chewed up, try this method. Put a 13mm socket in a pair of vise grips and use a 4mm hex through the opening to "hold" the adjuster shaft. Use the hex to just hold and try to turn with the socket set-up. You may be able to spin the 13mm nut up and correct the threads as you go. If not, you'll strip the 4mm hex. Once that happens, go back to #2.
solo1
Jul 1 2010, 12:58 PM
Thanks for the digs about the bleeder valve. D'oh!!
you guys friggin rock got the pistons out cleaned, re-brake fluid, replace inner seal split the halves to get the pistons back in and correctly alligned am working n the outer seal which i was told in a PIA the first time but ill get it. gonna clean the caliper up a bit as it is really unnattractive. have gone back and forth with eric in utah the rear doesnt look like something i want to tackle so im going to pull them and send to eric to do the re build etc. cant begin to thank you guys enough. with this repair am i no longer a newbie/virgin?
Eric_Shea
Jul 1 2010, 01:41 PM
Once we do your rear you will no longer be a virgin
(sorry... couldn't pass that one up)
underthetire
Jul 1 2010, 03:50 PM
Ouch
solo1
Jul 1 2010, 06:13 PM
Outstanding!!!
biggy72
Jul 1 2010, 10:06 PM
WOOO!!! finally got all of the pistons out.
But I do have a couple of problems with the one rear caliper:
1. The outter adjuster had a couple threads pulled off and a c clip was used to hold the jam nut in place.
2. The inner adjuster doesn't move the piston at all, but after spinning it for a little bit and then hitting the parking brake it does push out the piston. When I got close to having the piston out the adjuster gear that you put the 4mm hex in fell out.
Any ideas on what could be wrong? Also do you end up covered head to toe in grease every day? I now completely respect what you do.
bigkensteele
Jul 1 2010, 11:11 PM
QUOTE(Ericv1 @ Jun 28 2010, 06:08 PM)
Southeast is the only place to live if you are a teener... That is common knowledge, an coincidentally most convenient for me...
Eric_Shea
Jul 2 2010, 07:50 AM
1. The outer adjuster is supposed to have a c-clip holding the lock nut in place. You need to take it off prior to removal of the nut otherwise you'll muck up those threads. We have replacement adjusters.
2. The inner adjuster gear is loose in the cavity and comes out. This is not a problem. If you're close to having the piston out... the adjuster will lose it's affect as the piston has come off the adjuster. If you then pull the handbrake arm, the adjuster will move in the bore and come in contact with the piston again pushing it slightly. At this point it's time to remove the piston manually.
So... based upon all of this, it doesn't sound like anything is wrong other than a buggered up outer adjuster.
Cody does!
Latex gloves and coveralls help... actually, what work's best is a USPS Flat Rate Box and $249.00 bucks.
biggy72
Jul 2 2010, 01:48 PM
Ok I guess my problem was just that my other rear caliper didn't have this c clip in place. I thought the clip was a piece of pulled out thread, until I pushed it out of the way. This adjuster appears to be in ok shape since I didn't beat on it too much.
Also on the rear caliper the inner adjuster pushed the piston out. I couldn't get the other caliper to do it without pushing on the parking brake. I don't think I did anything different between the two calipers, but I may have.
And if I could afford it I would have sent them to you, but we just bought a house and that tends to get all of the extra money. I set a $500 limit on getting back on the road and that includes relocating the fuel pump and running new fuel lines. I think I will probably end up pretty close to that amount, but probably a little over.
Ericv1
Jul 2 2010, 06:13 PM
QUOTE(bigkensteele @ Jul 2 2010, 01:11 AM)
How far east Big Ken?
solo1
Jul 4 2010, 01:30 PM
am puting the calipers back together,fronts. when i took them out neither side had the piston retaining plate. the kit came with and eric says to use them. was very careful to make accurate markings on the housing to insure the pistons went back at the same angle they were at. however the retaining plates look as though they fit into the deep space on the front of the piston. if they werent thee the first itme do i need to use them? if thats the case then the guy that rebuilt them was incorrect in his angle and i will need to blow out the pistons and re assemble using the reataining plate. thoughts ?
Eric_Shea
Jul 4 2010, 03:20 PM
Blow them out and do it right. If the plates don't match them... they're in wrong. What year is your car?
If it's a late model car, do this:
1. Blow the pistons back out.
2.
Paint "brake caliper" assembly lube on the backside of the dust seal.3. Install the piston positioners. Make sure the center prongs are positioned properly. To do this, install the prong closest to the angle itself, first. Then push the remaing prongs down.
4. Starting with your two inside caliper 1/2's - look at the bleeder openings. Each caliper should have a round indent on one of the bleeders that I like to use as the "top". That is the direction of rotor travel, from that top. Make sure your positioning plates angle those pistons so the angle is facing the oncoming rotor.
5. Press the pistons/dust covers and positioning plates into the caliper using a steel plate. This will press the internal metal ring in the seal onto the flange on the caliper (this is why you needed the assembly lube).
6. Repeat the proper angle and piston installation proc. for the outside 1/2's
7. Bolt them back together using the proper piston angles and torque in the proper sequence to 17 ftlbs.
If it's an early model car you won't have:
a ) Dual bleeders.
b ) Integrated seal in the dust clip.
c ) Piston positioners in the kit (if you have single bleeder calipers and you received positioners, you probably got the wrong kit).
If you have early calipers with no positioner clips simply draw an imaginary line down the center of the pad cavity and place the bottom notch of the piston recess along this line. This will give you a 20 degree angle every time.
(I need to get paid by the word)
solo1
Jul 5 2010, 01:59 PM
got it thanks eric. talked with underthetire yesterday talked me thru it. next idiotic question the tie rod...mine is in good shape howevr at the joint closest to rotor there is a castlenut with cotter pin there is a rubber seal/gasket/cover mine is shot seems everyone wnats to sell the whole tie rod know we=here i s= can get this seal?
Ericv1
Jul 5 2010, 08:07 PM
QUOTE(solo1 @ Jul 5 2010, 03:59 PM)
George at Auto Atlanta might be able to get that seal. He has a bunch of parts most people wouldn't even think of.
solo1
Jul 6 2010, 12:58 PM
no luck finding this idiotic tie rod end dust boot. considering the age of the car is it worth it just to replace the tie rod end? how do i make sure that it is scewed back in to the correct depth or will it self set when it is in far enough?
solo1
Jul 8 2010, 12:04 PM
ok, okay im back with a brake question. when you take the calipers apart then get ready to re-assemble a couple of pages out there are talking about a brake rebuild grease, or something. The question begs, should something be put on the faces of the split calipers before re-assembling them? lube the piston with brake fluid only?
biggy72
Jul 8 2010, 07:44 PM
So where do you get 7mm x 1 bolts at? I had to cut one off and several of the heads are a little rounded. I'm having a heck of a time.
Ericv1
Jul 9 2010, 01:53 PM
QUOTE(solo1 @ Jul 8 2010, 02:04 PM)
I've used Plastilube in the past around the pistons. It's an assembly lube that can be purchased from Pelican. I haven't put anything on the faces of the split calipers. I may put a dab on the o-rings ( 911 M calipers) to hold them in place as I put the faces back together but that's it.
biggy72
Jul 11 2010, 11:23 PM
So I found the bolts on the Auto Atlanta website, but I can't find them anywhere else and I'd like to get them from someone closer so I can get them quicker. I tried Fastenal, Mcmaster Carr and Tacoma Screw (local), but I can't seem to find them anywhere.
I've got the caliper halves all put back together and painted so now I just need to find some bolts.
