pillay2k
Jun 29 2010, 04:17 AM
SUNAB914
Jun 29 2010, 05:00 AM
What happened? Was it towed backwards at 100mph or did the heat warp it. Never seen one warp like that.
veltror
Jun 29 2010, 06:10 AM
Hmm, early roof?
JoeSharp
Jun 29 2010, 06:33 AM
My guess would be that your car is bent. Somewhere around here there is a drawing of the car with dimensions on it that will tell you what the distance between the windshield and the targa bar should be. I have looked at car doing cross-sighting the targa and the windshield frame to see if they are parallel. That car was bent and we cut it up.
TheCabinetmaker
Jun 29 2010, 06:37 AM
Wrong seal on the rear of the targa.
jmill
Jun 29 2010, 06:38 AM
Click the link in my sig and see what Rick had to do to get mine straight. I had the same thing. It might be just the windshield frame is pulled down on the passenger side or your car is bent. PM Rick and get him in here. Mine is perfect now after he fixed me up.
pillay2k
Jun 29 2010, 07:36 AM
i'm hoping it is the windscreen frame like your John.
This car has had a new scuttle at some point so that might be where the problem started. I dont think the car is bent on the whole as the doors shut fine and there was no sign of accident damage when i took the car back to bare metal...
How can i tell the difference between a late and early roof? i have a spare that i could use but might be the same. One other thing is i have one early door (DS) and one late door (PS) (without the reinforcement) as i couldn't get 2 good matching doors... will have to pick some up next time i'm in the US!
detoxcowboy
Jun 29 2010, 08:16 AM
#1 correct top..
#2 is the latch system in good shape and mounted properly in there correct position both on the car and the targa ..
#3 take some measurements roll bar to windscreen, latch to latch ect.,door jambs to windscreen corners,
#4 also would look at the window triangles on each door and how they come up to the windscreen, this may give you an idea if the windscreen is twisted or bent,..
#5 when the car is jacked up is there any significant changes??
dr914@autoatlanta.com
Jun 29 2010, 08:27 AM
I can see clearly that your car needs a little "tweeking" on a frame rack. There are plenty in Britain who can do an excellent job. They will remove the bumpers and rockers, tie the car down and then set it up for a multi pull. That will get it all back in line and the top and doors and windows will all fit great.
QUOTE(pillay2k @ Jun 29 2010, 03:17 AM)
76-914
Jun 29 2010, 09:08 AM
Fab, Go to the top of the screen and select "914 info". You will find all the 914's dimension's, here.
Root_Werks
Jun 29 2010, 09:25 AM
The pass side door gap looks pretty small.
Get it on a frame machine, square things up?
Tom_T
Jun 29 2010, 12:54 PM
I agree with the suggestions above, but best check the longs for rust (if you haven't already done so), because a Cellette Bench or any other frame machine can litterally pull a car apart if there is significant rust damage. A local shop owner was telling me a couple of weeks ago how that happened when they tried to fix a customer's 70 914-6. So you'll need to fix any significant uni-body rust before you "stretch" it back in square on a frame machine. Also make sure the selected shop has the proper 914 fixtures & dimensions for it (they're posted at "914 info" up along the top of the webpage here).
Jun 29 2010, 01:25 PM
Before you go too crazy, try bending the top of the windshield frame!
If you are careful, you can do this without braking the windshield. You'll be surprised how easy this is.
There is enough adjustment in the doors and windows to get this all squared. It's not off by much.
Andy
pillay2k
Jun 29 2010, 01:26 PM
There is defiantly no rust on, in or around this car anymore (i must write up my resto at some point!)
I have measured front to back windscreen to roll bar and it is out by 4mm, diagonally it is a bit more...
The door gaps are probably more to do with hope much of the door was fabricated to make it whole again
Thanks for the info i will have to go on the hunt to get this 'straightened' out.
pillay2k
Jun 29 2010, 01:33 PM
QUOTE(SirAndy @ Jun 29 2010, 08:25 PM)
Andy
i was tempted as just my hand pushing down on the top of the frame can deflect it a couple of mm at least, bonus being i need a new screen and have new front trim to go in too, might be worth killing to birds...
Thanks guys.
