JeffBowlsby
Jun 29 2010, 01:13 PM
So how does this system work? Review these first two graphics from the factory repair manual to find out.
(PS I wonder why the forced induction guys dont't use the air from the fan housing to spin their turbos?
JeffBowlsby
Jun 29 2010, 01:28 PM
Then as a test, whats wrong with the charcoal conister installation on these diagrams? The first one is in the factory repair and Service and Training Manuals.
When you are done with this I have more...
JeffBowlsby
Jun 29 2010, 01:29 PM
Jun 29 2010, 02:22 PM
QUOTE(Jeff Bowlsby @ Jun 29 2010, 12:28 PM)
They both show the air from the fan shroud go into the wrong end on the canister ...
The pressure side on the canister is on the side with the two nipples. Fresh air and vapors come in from the same side. The vapor/air mix is then expelled on the drivers side of the canister and routed to the engine air-filter housing ...
What do i win?
Andy
JeffBowlsby
Jun 29 2010, 02:39 PM
Jahvol Mein Freund
Win? HA! This is a documentary...
But wait there is more. The later plastic case charcoal canisters can be opened up and the activated charcoal can be replaced (check Google for suppliers). This should be done...every 50K miles according to the repair manual.
Pat Garvey
Jun 29 2010, 06:52 PM
Jeff, you know you had to open a "can 'o worms" here.
What about the older cars? I was told by the local PD (dealer) in about '75/76 that the canister was self healing, in that it would clear itself & rejuvinate itself over time - like I believed that!
Charcoal has limited capabilities of absorbing hydrocarbons. Yes, it works fine for a few yeas of normal driving, but then it becomes, in the case of these pellets. over absorbed.. I suppose after that some " parked time" the pellets could clear of hydrocarbons, but would then absorb ambient moisture. Bad? Not certain, but I think so. And, when that moisture is released to the chamber & tank, corroson might occur.
Now, I seem to remember that there was a maintenance bulletin that recommended changing the canister on the early cars at around 50K. By that time (one my 914) they were unavailable.
So, given that my 914 is 37 years old, and isn't required to have emission testing in PA, would I be better off bypassing the canister? Is it of any value at this point?
Pat
JeffBowlsby
Jun 29 2010, 10:30 PM
Well Pat...
You can see the factory manual recomendaiton above indicating replacement at 50K intervals. Thats all I know. I dunno nuthin' 'bout the mineralogical properties of the activated charcoal, bet Google knows.
I believe its primarily an emissions thing...filtering raw hydrocarbons from the air (the fuel tank is not pressurized, its open to the atmosphere). If people smell gas in their cabins, it must be a faulty hose, loaded-up charcoal canister or some other flaw in the system.
OR, you could find an NOS charcoal canister correct for your model year...OR you could locate a later-issue <gasp> plastic canister and change out the charcoal as in the above picture.
Next chance I get I will post photos of the different styles of canister and their different locations...
How many different canister styles were their? How many different mounting locations?
JeffBowlsby
Jun 30 2010, 10:03 AM
A 1970 model
JeffBowlsby
Jun 30 2010, 10:04 AM
VIN 4712908458
JeffBowlsby
Jun 30 2010, 10:05 AM
VIN 4722907659
JeffBowlsby
VIN 4732903509
JeffBowlsby
Jun 30 2010, 10:06 AM
VIN 4732914926
JeffBowlsby
VIN 4732926371
JeffBowlsby
Jun 30 2010, 10:07 AM
VIN 4742905929
JeffBowlsby
VIN 4742915964
JeffBowlsby
Jun 30 2010, 10:09 AM
From the 1975 Service and Training Manual
JeffBowlsby
VIN 4752903075
JeffBowlsby
Jun 30 2010, 10:10 AM
VIN 4762901268
Jun 30 2010, 10:37 AM
QUOTE(Pat Garvey @ Jun 29 2010, 05:52 PM)
When i removed mine ('70 914-4), i opened it up to have a look inside. It was empty!
I guess after 30+ years, all the charcoal inside had turned to dust and was happily burned by my engine ...
Andy
Peter Zimmermann
Aug 23 2011, 04:11 PM
QUOTE(SirAndy @ Jun 30 2010, 08:37 AM)
Andy
FWIW; this is the only suitable place I could find on my '74 1.8 (VIN 7173). There were no holes in the left side body to bring the lines forward from the shroud/air cleaner, and the car did have the 5mm plastic line in the tunnel. Result? No fuel smell at all in the car or garage.
Pat Garvey
Aug 24 2011, 07:16 PM
QUOTE(SirAndy @ Jun 30 2010, 10:37 AM)
Andy
That is so funny! But probably true. Think I'll open mine up & see what's in there!
1970 Neun vierzehn
Aug 26 2011, 09:24 PM
Not all 914s had a charcoal canister. This, from an early '70/4......
1970 Neun vierzehn
Aug 28 2011, 06:00 PM
the '70/4 is a 49 state car, built date 01/1970
mountainroads
Jun 19 2013, 02:26 PM
This is a great thread. Can somebody please confirm if the same system was used on the -6 models? (I've looked, and I can't find a definitive answer.) Thanks.
- MR
jrrhdmust
Jan 10 2014, 12:13 PM
so can someone tell me where to pick up new charcoal for the system?
Thanks
Pat Garvey
Jan 16 2014, 08:00 PM
QUOTE(mountainroads @ Jun 19 2013, 03:26 PM)
- MR
Nope.
Pat Garvey
Jan 16 2014, 08:01 PM
QUOTE(jrrhdmust @ Jan 10 2014, 01:13 PM)
Thanks
Me too!
euro911
Jan 16 2014, 09:43 PM
I don't run one on the BB, but I'm sure my wife's car needs the charcoal replaced
1970 Neun vierzehn
Jan 17 2014, 03:22 PM
QUOTE(Pat Garvey @ Jan 16 2014, 06:01 PM)
Thanks
Me too!
I don't think you need the charcoal Pat, since your car hasn't run in, what, 15 years? But if you
really would like some charcoal, maybe your local WaWa might have some.
Pat Garvey
Jan 17 2014, 05:43 PM
QUOTE(1970 Neun vierzehn @ Jan 17 2014, 04:22 PM)
Thanks
Me too!
It's only been 7 years! I've told you a million times not to exaggerate. And, don't you dare denigrate my WAWA (not the George Harrison variety).
rhodyguy
Jan 23 2014, 09:35 AM
there's no need to spend what seems like a small fortune on a couple of pounds of pellets. i found them at amazon. be careful of the small line fitting while opening and closing the canister. with carbs and the stock rear firewall location there will be fitment issue. you'll need to drill a small hole closer to the centerline of the engine to accommodate a bolt (same size as the stock mounting stud) for the bracket.
euro911
Jan 23 2014, 01:59 PM
Does it matter if it's installed at the fuel tank, or in the engine compartment?
Where's the better (most efficient) location?
rhodyguy
Jan 24 2014, 08:39 AM
pretty sure the line locations and the lengths will dictate placement. on the 74' i'm working on, the small plastic line to the canister from the tank runs to the engine compartment thru the center tunnel (i think). its long enough to run to the stock rear firewall mounting point. the large line (single) from the port on the fan shroud (pass side) is in the engine compartment. the canister is the plastic version. trying to replicate the stock setup and to determine exactly how to use the carbs to draw off the vapors. i'll post some pictures later.
the canister, metal, on my 73' would be mounted on the fuel tank with the 2 long shroud lines running under the dr side rocker and a short small line to the nipple on the canister from the tank.
euro911
Jan 24 2014, 02:09 PM
The 'BB' is a '75 and the small diameter hose is still there, so It would probably be best to find a good location in the engine bay
Porsche930dude
Feb 20 2014, 08:44 PM
i just removed the canister from my 911sc since the hoses were shot and the removable end just about removed itself. probrobly empty by now im going to open it up and see. But im thinking is the canister there just for when the car is turned off and the fumes have a place to collect? because when its running it suckes the fumes in anyway and it doesnt get to the atmosphere. So by that theory i can bypass the canister and still plumb the lines to the intake and the fumes will just pool in the intake instead. potentially causing a big backfire when started perhaps. so would i be better off venting it to the atmosphere or leaving it plumbed to the intake. Im not real woried about smelling fumes but id rather not blow my airbox.
Harpo
Apr 13 2014, 05:59 PM
Before I saw your post I was thinking the same thing. However you bring up a good point.
David
Pat Garvey
Apr 17 2014, 06:20 PM
QUOTE(1970 Neun vierzehn @ Jan 17 2014, 03:22 PM)
Thanks
Me too!
I'd like to set the record straight here it's only been 10 years. Naberhaus, you are sooo negative. Relax, take lessons from me. It's not WHEN it runs, it's HOW it runs. Rome wasn't built in a day.
Apr 17 2014, 06:59 PM
I just bought some on amazon. $10 for a 3lb bag. Hopefully the canister can be serviced on a '71
euro911
Apr 17 2014, 07:52 PM
So it appears that almost any pet supply store should carry it
Will a 3lb bag do the trick?
Apr 18 2014, 03:45 AM
QUOTE(euro911 @ Apr 17 2014, 09:52 PM)
Yes. Saigon did his and measured 1.7lbs in the canister.
rhodyguy
Apr 18 2014, 08:56 AM
i tried all of the pet stores, both big chain and independents, in my area before i looked at amazon. the pet stores didn't offer the activated charcoal in PELLETIZED form. all i found were expensive big clunky chunks.
Bleyseng
Apr 25 2014, 05:07 AM
euro911
Apr 25 2014, 05:18 PM
Cool. Great link, Geoff
partwerks
Jun 25 2021, 06:08 PM
QUOTE(Jeff Bowlsby @ Jun 30 2010, 08:05 AM)
VIN 4722907659
Any pictures of how the band that goes around the canister, mounts to the channel on the gas tank?
StarBear
Jun 26 2021, 11:26 AM
QUOTE(rhodyguy @ Apr 18 2014, 10:56 AM)
Our local fish store (yes, we still have one) has the pelletized form. Enough for 2 fillings.
davep
Jul 15 2021, 10:31 AM
Do you have a UPC from the package of pellets, or at least a brand name to look for?
BTW, I weighed the pellets I removed from a plastic unit, and it was exactly 800 grams. Or 1.8 lbs.
StarBear
Jul 15 2021, 05:03 PM
@davep . I got Acurel Extreme Activated Carbon Pellets. 45oz. Www.acurel.com. I think it was $24.99 or so. Clearly enough for two fillings.
914werke
Jul 15 2021, 06:29 PM
Lets keep this going
Since so many cars have been converted to carburators it only makes sense to address
how if at all you can still use the evaporative system?
I know many people complain about the fuel smell that can permiate thier garage after
putting away thier carb'd car.
What is the best way to plumb the motor to lessen that effect? Is there one?
Edit : whoops! i didnt notice this was in the Originality sub!
robkammer
Oct 29 2021, 11:01 AM
Wow, an 11 year old thread! Jeff had a lot of time on his hands in 2010. I'm trying to put my 74 BB back to as original as possible and it came without a canister or hoses or a bracket. I now have a bracket but I'm wondering if finding a canister is going to be as difficult as finding an AAR valve.
partwerks
Dec 8 2021, 06:28 AM
QUOTE(1970 Neun vierzehn @ Aug 26 2011, 07:24 PM)
That's what my mounting tab looks like. I'm wondering if I have the wrong canister, with the band that goes around the canister, don't make sense for attaching the two together??
