you can read alot about the a/c system condition by the high and low differential readings, but it looks like you covered all the bases.
on a system without info. on the charge amount needed you can get a fairly accurate fill by watching the frost line move up to the condenser (and watching the high side pressure). kind of like the old systems using a sight glass to visually watch for the charge to change from bubbles to solid.
you have an orface tube in there so ideally your 1200 rpm should be constant with other rpm's. note: did you change your orface tube? same color?
the clutch cycles out when the pressure is high out of range. some are low/high. by using the above frost fill method first, a cool trick i used to do was tune the pressure cut out switch. use a temp gauge in the vent for temp. varificaion then remove the pressure switch electrical plug, with a small flat screw driver turn in or out just a little, plug back in and check temp.s. this alters + or - the cycle time, raising or lowering high side pressures. all part of balancing the orface tube/evaporator size to the pressure/cycle time
that was long huh? i just love a/c crap though
