bandjoey
Jun 29 2010, 08:11 PM
I've been on Search, Haynes, Dr evil's Appendix, and still can't come up with the torque for the bolts through the CV to the transmission.
Help?
mihai914
Jun 29 2010, 08:15 PM
31 ft-lbs, it's in the Haynes called axle flange bolts, I think in the rear suspension section.
Edit: while you're in there check the bolts on the stub axle side, they can work loose.
jt914-6
Jun 29 2010, 08:18 PM
31 Bill 31.....
RJMII
Jun 29 2010, 09:03 PM
You doing the safety wire version?
(since you metioned Dr Evil's appendix; and I took over the CV bolts he was doing; I thought I'd ask)
Cupomeat
Jun 29 2010, 09:32 PM
I am not even going to ask HOW you got to searching Dr. Evil's appendix!
curt914
Jun 29 2010, 09:59 PM
OK... so I have a question...
I just lost an outboard CV joint because all of those bolts were loose and it all came undone at speed last Friday.
So how do you safety wire the cv bolts that are on the stub axle side?
I mean those things are kinda buried in the trailing arm and on top of that the boots kinda get in the way.
Does the wire need to be arranged in some way (sort of like aircraft bolts that are safety wired) to be actually effective?
Thanks
Curt
bandjoey
Jun 29 2010, 10:08 PM
31..Thanks. It's all the different ways to call a bolt a bolt...axle flange bolt.
I need to order some wired bolts. When I pulled the tranny, a couple of the bolts were loose.
As to his appendix, he put it online to download. Now I'm waiting for the DVD for more revealing images. Messy I'm sure, but revealing. I guess Doctors don't need appendix's anymore.
Jim. I'll send you an order. Are there picture instructions on how to wire? This might be advanced mechanics. A pelican level 8.
McMark
Jun 29 2010, 10:42 PM
Curt, pull the outer stub axle.
RJMII
Jun 29 2010, 10:43 PM
Bill; yes! the pictures are in the member vendors thread that Dr Evil started.
link to make it easy on you:
http://www.914world.com/bbs2/index.php?showtopic=54963Level 7 tops.
Edit: yeah, check the outers, also. Follow the instructions that Mark gave to Curt.
Do we need to have a CV-joint wiring clinic?
curt914
Jun 29 2010, 10:55 PM
Hi McMark
"pull the outer stub axle."
OK, yeah that makes sense, did not think about that as I have not gotten into that part of the car yet.
Mark, did you get more seals to build the speedo drive modification?
I'd like to order one when they are back in stock.
Curt
pcar916
Jun 30 2010, 08:09 AM
A small tip on cv's and the grease they occasionally sling.
After they are torqued onto the axle, stub axle, and transaxle flange, clean the circumference of the cv with acetone. It's better to avoid getting any on the boots for obvious reasons. Although that stuff evaporates so fast it usually makes no difference.
Then wrap the circumference with HVAC aluminum foil tape. Most handy folks who have been exposed to this stuff have some of this hanging on the wall.
Note: After duct-tape, it's the most useful tape in the arsenal.
jeffdon
Jun 30 2010, 08:15 AM
QUOTE(RJMII @ Jun 29 2010, 08:03 PM)
HIGHLY recommend these. No more 12 pt head, and a good measure of piece of mind.
IronHillRestorations
Jun 30 2010, 09:36 AM
FWIW after I get the CV, gasket, and one bolt hand tight, I clean the grease out of the threaded holes on the output flange with a q tip drenched with brake cleaner. I always use new schnor washers and a tiny drop of blue loctite on each clean and dry CV bolt, torqued to the proper spec.
Not trying to pee in anyone's Wheaties, but since I've done it like this, I've never had a CV bolt come loose.
tat2dphreak
Jun 30 2010, 10:46 AM
QUOTE(9146986 @ Jun 30 2010, 10:36 AM)
I used the allen head bolts, but didn't need loctite, with proper torque they have not backed out on me. new washers was key though.
McMark
Jun 30 2010, 11:22 AM
The safety wires bolts a great peace of mind, but strictly speaking aren't necessary. Even so, I still recommend them because it's one less thing to worry about and it's cheap security.
brp986s
Jun 30 2010, 12:35 PM
I don't wanna pee in wheaties, but am on furlough today so have time to
the
I bought custom length cv bolts from Patrick for a 915/wevo. They were stamped 11.9. If you've substituted garden variety 8.8 bolts, does the 31 ft-lb setting still apply? Or is it just a function of thread pitch? Or is all hardware these days counterfeit crap made outside
RJMII
Jun 30 2010, 01:04 PM
The bolts I sell are 12.9; and offer the peace of mind that McMark mentioned.
I recommend following the 31, and safety wiring them.
If they come out, something is very very wrong.
smontanaro
Jun 30 2010, 01:18 PM
I have the Evil bolt set in my garage patiently awaiting installation. Assuming I get around to that sometime before the world comes to an end, do I just cough up the $$ for the star bolt wrench or is there a way to pull them without it (maybe a hex will work)? It will, after all, be a single-use item. (Or are there other applications of these wrenches on our cars?)
Skip
McMark
Jun 30 2010, 02:57 PM
If you bought hardware store 8.8 bolts don't torque them to anything, just leave them loose and drive around the block. That way you're close to home when they fail.
**Apparently I'm in a mood today.
Jul 1 2010, 06:51 AM
FWIW I always get the CV bolts and washers from Porsche, they aren't too bad.
Skip, you've got to use the triple square hex, if you try to use a regular allen, you'll strip them out, I know from 1st hand experience (1980). You can re-use the bolts, just not the serrated washers.
