I would assume by VM you mean the dash gauge?
I would check the voltage right at the battery cable. (Not the post) Then switch lights on. More than likely, if it is charging, you have a high resistance connection somewhere. (Corrosion, etc.)
Use a handheld voltmeter, and after the battery, check it on the back of the gauge. Then check on the ignition swith, fuse box, etc. I would almost bet on the fusebox, or the relay board.
-- brett
QUOTE(timofly @ Jun 29 2010, 07:20 PM)
VM works normally, showing 13-14 volts with 1000 rpm. When parking lights and/or headlights are turned on, it pegs to the left (low) regardless of rpm.
Where do I start? Grounds? Relays? Alternator and battery are new.
I'm no electrician, but I have the usual collection of meters with mysterious scales and markings....
