QUOTE(detoxcowboy @ Jun 30 2010, 07:09 AM)
74 2.0 Stock
I have a New Bosch 3 Port Fuel Pump Installed and all fuel lines/tank/injectors/press.reg. are currently empty.. How do I fill the system prior to starting the engine? Do I need to connect the fuel pump directly to the battery and run it? If so how long? Pictured below.. Which side is positive terminal? or does it matter? Any advice appreciatied..
Thanks ..
Click to view attachmentJoe - did you relocate it to the area behind the steering rack up behind the steering rack cover, per the Porsche+Audi/VoA service bulletin? If not - since you're doing so much to resto yours before the "trip to the far north" - you might want to do that now with the kit from AA to avoid hot weather/long drive vapor lock with it in the stock engine bay position.
Mine was done in late 70's after vapor lock had me stuck in Blythe Denny's for 2-3 hrs. waiting for it to cool down, while on the way to the River one 4th weekend - but nary a problem for 50-70+k miles after reloc.!
Email me if you want hi-rez pix of my FP reloc. done by Hans in HB.
It should prime & runs itself with a few key clicks in either position, as the others have said.
Where did you find a source for a proper new Bosch 3 port, as I'll need one for my resto?
