QUOTE(smg914 @ Jul 3 2010, 03:29 PM)
You need to use both gaskets.
Install everything in the following order.
gasket
strainer
gasket
cover plate
Yes!! you need two new paper gaskets, one goes on each side of the strainer. I suspect you had two , but the upper one stuck to the engine case when you drained the oil and did not see it.
i would not recomend sealers, as they will be a clean up issue each time you change oil. I have NEVER needed any sealer on my 914 motors ever on this cover plate all with no drips. if you still leak with new gaskets, then maybe the plate is warped? also there should be a one use only crushable metal washer under the big nut.
note I have been able to reuse the gaskets once or twice, but generally i replace them to be sure of no leaks.
NEVER EVER FRICKIN EVER double up on the torque for the large oil plate nut, never ever do that . the piece that it screws onto is mounted on a fragile aluminum casting that cantilevers out on the case, you snap it, adn you must pull the entire engine apart to repair. NEVER EXCEED RECOMMENED TORQUE on this part ever!!!!
as a new owner, you should be aware of teh SM rated motor oils and the lack of zinc (ZDDP) in them. the lack of ZDDP in new motor oils may ruin your cam. you need to use a speciality oil such as Brad Penn, or use an additve to regular oils A common additve is STP red bottle four cylinder oil treatment, add the pint bottle to each oil change in teh 914. do a search on zddp and oil here or on the web. your 914 NEEDS the higher zinc content.
dont forget these cars need frequent (6000 mile0 valve checks/adjustments. when you do them, you will want a new valve cover gasket each time, and some gasket glue to place on the cover side only.
good luck with your fine new car!!!
p[ost some photos please!!!!
have fun
