QUOTE(Kevins911 @ Jul 3 2010, 10:23 PM)
Thanks, I'll adjust the push rod. I did a bunch of reading on the brakes prior to posting this and came across the SS brake line info...there on the "to change" list, especially for a street car.
Cheers
Kevin
Stainless wrapped teflon is hardly piece of shit brake hose, Me and 914 friends have safely enjoyed them for many many many years. just install them carefully like, make sure they wont twist or bend sharply under suspension travel and wheel turning and you will be fine. if your extra anal, get the DOT approved stainless lines, they have a plastic strain relief on the ends.
likely master is not venting back, push rod too long is one possibility (it has to be able to freely move all the way back when you let off the pedel.) dirty clogged up junk in the master is other possibility, (maybe junk from a dirty resivoir? seeing as the master is new)
for sure the stainless/Teflon hoses are not the probelm, they dont swell like shitty stock rubber hoses do. after the umptenth time checking the rubber hoses for swelling and the brake drag induce by swelling, you tire of them. Change out a brake caliper that failed as in cooked do to over heating becuase the rubber line swelled, and you wont ever want them again.
good luck
