QUOTE(jaxdream @ Jul 5 2010, 09:07 AM)
If you have a Haynes , use that procedure. The adjustment for the master cylinder pushrod is on the brake pedal arm, the pin with the cotter pin through it has a jam nut on the rod which is loosened and the rod turned into / out of the master cylinder. That is the adjustment not the whole pedal assembely , it is a feel type of adjustment due to the fact that the rod does pass through the rubber boot that surrounds it but it can and has been done many many times , you have a 914 not a bus or bug. Good luck and do yourself a favor and use the correct procedure , you'll come out better in the saftey standpoint of brakes.
Jack / Jaxdream
I agree completely, jaxdream.....May I also include this, The adjustment rod is rounded at the end and fits into a corresponding borehole in the mastercylinder. I have found that removing the push rod, cleaning it up, especially the rounded end, and cleaning /wiping out the M/C bore hole is the thing to do. More than likely you will find RUST/rusty goo/debris etc. A light coat of motor oil in the M/C borehole,and on the end of the rounded pushrod provides rust protection and lubrication ensuring an accurate pedal freeplay setting. when finished, You'll be good for many many years.
