mipstien
Jul 6 2010, 01:41 PM
which wires are what on the fuel injectors rounded part of the plug is at the bottom and there is a left and right wire. are the right wires the power and the left a ground?
detoxcowboy
Jul 6 2010, 02:08 PM
I do not think it matters whihc way you install the plug on the injectors off the harness, I asked the same thing awhile back when I bought a new harness, was told by the maker it did not mattter, and have installed them both ways ..
mipstien
Jul 6 2010, 02:34 PM
My problem is a broken ground. And I don't wanna ground the power wire. Without a vground its hard to figure out which one is getting power and which isn't because they both get power just not finishinjg the circuit
JeffBowlsby
Jul 6 2010, 03:00 PM
Check continuity of the broken wire to ground with an ohmmeter. If no continuity to ground, its not the ground wire, its the wire to the ECU.
mipstien
Jul 6 2010, 03:46 PM
i did already try this. but i was hopeing someone could tell me what wire was what. i just wanted to make sure that power was on the right and ground was on the left basically.
JeffBowlsby
Jul 6 2010, 05:42 PM
That's generally correct, but I have noticed in taking apart hundred of these FI harnesses that they are not always wired the same, sometimes the wires are switched. I didn't want to give you false information when yours could be different, but rather a way to verify exactly your condition and be sure. The injector does not care which wire is which, its just a simple solenoid.
mipstien
Jul 6 2010, 06:06 PM
thanks just wanted reassurance with it i sure didn't wanna fuse a wire and blow up a battery or ecu trying to ground out something like that. funny thing when i made sure the ground was 'perfect' and cleaned up everything the car stopped stuttering and starting running like a car again. bad ground on the injectors makes all the difference.
