I've installed my oil cooler and am now hooking up the fan. I'd like to pull the fan's power from the relay board. I have drawn lines on the picture below to show how I want to wire it. I will be using the "spare" fuse on the relay board and pin 9 on the engine compartment wiring connector. I looks like nothing uses this fuse on the relay board. The power for this fuse appears to come from the hot side of fuse 8 (under the dash) and is hot with the ignition "on" (tested).
Does anyone see fault with my plan?
thanks
-Rob
btw I will update the oil cooler thread I started with pictures of my cooler install.
